Country: Senior Java Engineer
development experience using Node.js, Java, Python, .NET or similar technologies. Proven ability to design and build scalable... | Senior Full-Stack Engineer | Technology Consulting | Belfast In Digital Engineering we shape, concept and build innovative...
based in London, Sheffield, and Bristol. About the role As a Senior Microsoft Power Platform and AI Developer.... You will design how agents use trusted knowledge, approved tools, Model Context Protocol (MCP) services, approvals, human hand-offs...
connected and supported. We are seeking an experienced Senior Power BI Developer to design, develop and support modern... opportunity for someone who enjoys working across the full BI lifecycle, from requirements gathering and solution design through...
💼 Workstream: Finance / Operations Reporting Modernisation Are you an experienced Solution Architect / Lead Engineer...: Design production-grade Python scripts (pandas, oracledb, SQLAlchemy, openpyxl, etc.) to replace Access macros, automate...
deployment and monitoring. Solution Development: Support the design and implementation of data science and AI solutions... Job Description As a Senior AI Engineer, you will play a key role in building, deploying, and maintaining machine learning and AI solutions...
Deployed Solution Engineer (FDSE), you act as the CTO of the build-owning everything from backend services to LLM pipelines... and front-end integrations. You partner with customers in the field to design, implement, and deliver solution-ready builds...
Deployed Solution Engineer (FDSE), you act as the CTO of the build—owning everything from backend services to LLM pipelines... and front-end integrations. You partner with customers in the field to design, implement, and deliver solution-ready builds...
